Wrong number of sample acquired with Matlab script
Hello everyone,
I'm using a NI 6229 to read a series of analog signals. On a matlab script I use to pilot the hardware, I set the rate at 50000S/s to read 5 channels on the DAQ, while moving a motorized stage. Everything works fine until NumberOfScans = 1000, if I increase the number of scans over that value I can acquire only 1000 points per channel plus series of 0s. I expected to be able to increase it until 50000.
I attach the script.
Thank you for your support
Marco Nardello
(1,202 Views)
Dear Marco,
Number of scans for operation when starting - MATLAB (mathworks.com)
Having looked at this article from MATWORKS's support page I assume that NumberOfScans value must be multiple to 1000. And 1000 is the number of scans per second.
Hope this will help you to understand the issue.
Best Regards,
Hitting the KUDO button is the best way to say "Thank You"
(1,105 Views)
