XP Embbeded DAQmx driver for USB-6008 OEM
We are using the USB-6008 OEM to interface our system components such as motors, electrical valves, leds and switches.
We wrote our software in .NET 3.5 invoiroment and we are using at the moment the DAQmx 9.1 driver in our image application.
As you must know the DAQmx 9.6 is full with services and applications that is not needed if we use it only for the 6008 driver.
Is there any other driver for our needs?
Eliran.
(3,194 Views)
The 9.1 and 9.6 versions are similar in size and the download pages for both have links to core versions. These are the minimum DAQmx drivers.
(3,184 Views)
Is there a driver that is specific and only of the 6008?
(3,172 Views)
Hi Eliran11,
No, there is not a driver for 6008-only.  The dependencies for our hardware drivers are tied into a modular architecture that require the whole framework to be present.  The core download is the smallest you can get.
Chris Elliott
x36772
(3,164 Views)
