XP hangs at shutdown with NI-6509 connected
Every time when the 96-channel DIO USB-6509 is connected, Windows XP hangs during shut-down. It' possible to go to the start menu en press shut-down, but befor you get the last pop-up with "restart", "shut-down" or "cancel", Windows XP hangs. The hourglass is continious on the screen and no other actions are possible. It's even not needed to open labview first. When the USB-6509 is not connected to the PC, there is no problem.
MAX 5.0 is installed.
Does someone knows a solution for this problem?
(2,956 Views)
Hello Johan,
That indeed seems very unwanted behavior.
Can you provide me with some more information about the system you're currently using?
I'm especially interested in driver and OS information.
This can be found in the following way:
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4?OpenDocument
http://digital.ni.com/public.nsf/allkb/DDF39729A407BFC1862578F7007807A3
Next to this I would also like to know if everything works perfectly from MAX:
- Are you able to use the card from in there?
- Do you get any errors/warnings in MAX?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,914 Views)
