accesing daqmx internal channels with matlab daq toolbox
doesany one know how to add the internal channels (ie ao0_vs_aognd) to matlab input task?
i onl ysee the option to add the 16 physicsl input channels.
thank you
Dan
(3,157 Views)
Hi Dan,
Are you using DAQmx tools (look link)? I am not sure how to do it internally but you can try one of the subset of names taken from DAQmx C reference help installed with the driver:
Internal Channels for M Series
_ao0_vs_aognd
_ao1_vs_aognd
_calref_vs_aignd
_aignd_vs_aisense
Have you tried to use LabVIEW with MathScript to run the code (read more)?
Good luck,
Gerardo O.
RF SW Engineering R&D
(3,149 Views)
No support here?
Xu Laboratory
University of Washington
pasqual[at]uw.edu
(2,228 Views)
