acquire 4 oscilloscopes data synchronously through gpib or usb
I require to acquire 4 oscilloscopes data synchronouly through GPIB or USB instruments in a single LabVIEW VI.Is it possible to do that?.can anybody explain me if it is possible or another solution if not possible.
(2,751 Views)
For 4 separate instruments, you would need to send a trigger signal to all of them to initiate a sweep. With GPIB, you have the GET (Group Execute Trigger) or you can use an external trigger (i.e. a voltage signal). I'm not sure how the software trigger is implemented with USBTMC instruments. That's a technical question for the scope vendor.
p.s. In the future, post similar questions to the Instrument Control board and not the multifunction DAQ board.
(2,749 Views)
