ai.voltage.rngs property reports wrong values
When I read Devce Node "ai.voltage.rng" roperty for PXI-6163 in Labview, I an getting an aray {-1.25, 1.25,-2.5, 2.5, -5, 5, -10, 10} instead of instead of specified range values spnanning 0.1 to 10.
Is this propery broken?
(3,142 Views)
Accepted by topic author Fedor
Hi Fedor,
Those are the correct ranges for a PXI-6133, as listed in the NI 6132/6133 Specifications. The PXIe-6363 returns {-0.1, 0.1, -0.2, 0.2, -0.5, 0.5, -1.0, 1.0, -2.0, 2.0, -5.0, 5.0, -10.0, 10.0} for AI.Voltage.Rngs, which seems to be what you're expecting. There is no PXI-6163. Which board do you actually have?
Brad
Brad Keryan
NI R&D
(3,127 Views)
I'm sorry, I think I've looked into wrong spec. table.
(3,115 Views)
