amplifying analog output
I would like to use the analog output of a NI-6008 to control a proportional solenoid valve, either 0 - 5V or 0 - 10V, but the 6008 does not supply enough current to do so directly. I thought I had seen an amplifier circuit somewhere on the NI site but I am unable to locate anything like that. Does someone have a circuit that I can use?
(3,341 Views)
Just look in Digikey for a digital buffer chip that can output the current you need.
(3,339 Views)
Can you provide an example of what chip I might use? Sadly, my theoretical side in electronics has declined as I am mostly doing repairs and not design. Of course, if I were allowed to use 'spare' and 'time' in the same sentence, I would use that to study more!
(3,335 Views)
What are the current and voltage requirements for your solenoids? Even someone who has a lot of design experience needs numbers to start a design.
Lynn
(3,328 Views)
The 0 - 5VDC requires 375mA maximum while the 0 - 10VDC model requires 185mA maximum.
(3,326 Views)
One easy approach would be to use a power op amp. OPA569 up to 2 A, but limited to 5 V. LT1970 500 mA 36 V. LM675 3 A 16-60 V.  I found these with a quick Google search. There are others.  You may need to include protection diodes, heat sinks, and other related parts.
Lynn
(3,317 Views)
Thank you for the information! I will explore those leads as soon as I can.
(3,312 Views)
