amux-64t w high res DAQ card
Daniel,
Programming the 64 channels needed is not that complicated. If you have multiple Channels that will have the same configuration, like minimum & maximum values, terminal configuration, what you can do is that you place one DAQmx Create Virtual Channel vi, and when you wire the channel control you can select multiple channels to be accessed using this format: "DevX/ai0:63", where DevX is how you see your card in MAX and then the range of channels you want to access. This way you only need one task and you program it the same way as if it was one channel. If your channel are going to have different configurations then you can group them and add as many DAQmx Create Virtual Channel VIs as needed and wire them in  cascade.
Miriam
Field Applications Engineer
NI Colombia
CLD
Message 11 of 11
(656 Views)
