Hi all,
we are using DAQ Card-6024E device for I\O applications. We started by testing the digital I\O channel, it's working well, which doesnt hold for the analog I\O. we are using RSE input mode so we connect a sinewave signal generator between ACH0 and the AIGND pins; the output is too strange, we have a dc output with amplitude -10! no matter the input signal is changed, we have the same output; no matter the connection type is changed to differential (with the mode changed) we still have the same output. We opened this forum and checked similar problems, we set the mode to "Refrenced Single Ended" at the device properties... we still have the same problem.
we have also another problem with the analog output... we connected our oscilloscope between DAC0OUT and AOGND... no signal is detected.
it is good to state that we are using the factory-default configuration of the switches onboard.
we would appreciate any devicer... thank you all...
