analog input on digital external trigger
I am using  a NIDAQmx labcard and somehow I can still not figure out how to do the following:
Have a digital external trigger (I was thinking of DAQmxCfgDigEdgeStartTrig(handle, "Dev1/port0/line0", DAQmx_Val_Rising)) and read an analog input and do some other stuff. This should be a fast application, working at 5kHz. I would like to know which functions to use for this. I need the data from only two channels and one datapoint per trigger.
What I have and does not work is:
DAQmxCreateTask("AnalogIn", &m_hai)
DAQmxCreateAIVoltageChan(m_hai, "Dev1/ai0", NULL, DAQmx_Val_Cfg_Default, 0, 10.0, DAQmx_Val_Volts, NULL)
DAQmxCreateAIVoltageChan(m_hai, "Dev1/ai1", NULL, DAQmx_Val_Cfg_Default, 0, 10.0, DAQmx_Val_Volts, NULL)
DAQmxCfgSampClkTiming(m_hai, "", 5000, DAQmx_Val_Rising, DAQmx_Val_HWTimedSinglePoint , 1)
DAQmxCfgDigEdgeStartTrig(m_hai, "Dev1/port0/line0" ,DAQmx_Val_Rising)
DAQmxStartTask(m_hai)
for(int i=0;i<1000;i++)
        DAQmxReadAnalogF64(m_hai, 1, 10.0, DAQmx_Val_GroupByScanNumber, array, 3, &read, NULL)
        /* Here is some extra stuff*/
m_ni6221.StopTask(m_ni6221.m_hai);
I hope that anyone could help me on short notice, with best regards,
Arno
Message 1 of 1
(3,024 Views)
