analog signal generation & measurement
Hi
When I try to run this circuit below, it works fine
But when I try to combine the circuit into one loop just like in the attachement below, the error message pop out
Why is that happen? Is that possible I want to combine the circuit in one loop?
(3,480 Views)
Accepted by topic author yusof
Hi Yusof,
Good post. The problem you're running into here is that your write loops has to execute at least 4 times/second (20kSamples/sec / 5kSamples/iteration) while your reading loop has to execute 10 times/second (10kSamples/sec /1kSamples/read). The DAQmx write should determine the loop speed because it won't write until there is space in the write buffer. To do this, change the samples to read to -1. This tells labVIEW to read all available samples in the buffer.
Best,
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
(3,459 Views)
