analog trigger?
Let's see if I can explain what I am aiming to achieve. I am acquiring a 0-50mv signal from a gas detector. The baseline of my source moves around quite a bit. Sometime it is up around 8mv sometimes around -1mv. The background is about 1.5mv. I am using a USB-6008 for now on AI0, single sample, +/-1v, diff.
Once I put a sample into my detector the voltage rises and can be read easily. It ramps up quickly and has a slow decay.
My question is sort of 2 parts.
The attached png demonstrates what my signal looks like as well as what I need to do with it after. Due to the nature of what I am doing I need to calculate the area under the acquired curve. This is calculated using summed averages/time.
1. Right now I start the acquisition manually and use a variable to set the baseline as I do not want the background to be part of the calculated area. I want to be able to get Labview to start acquiring when it sees a delta change on the input signal. This way anything equal or above that trigger point will be used in the calculation. Right now I just run it on a user selected time period but need it to start at a trigger point and stop acquiring when the signal returns to that point on the downslope.
Mike
(3,194 Views)
Hi Murph,
The 6008 does not have analog triggering capabilities, but you should be able to implement what you want in software.  Try starting with this example:
Continuous Acquisition with a Software Analog Start Trigger
Best Regards,
John Passiak
(3,186 Views)
