02-18-2010 11:15 PM
Suppose I have a set of discrete numerical data(say 3,3.4,4.5,4.7,etc). I have to plot them in a graph as a waveform.
Kindly send me a module that will plot these values as a waveform. It will be good if the time gap between plotting of two successive data is alterable.
02-19-2010 08:57 AM
A waveform is composed of three pieces: an array of doubles (the y values), a start time of the waveform (t0), and the time between each y value (dt). By using the Build Waveform VI you can assemble these three pieces of information into a waveform and plot them on a chart.
Alternatively, waveform graphs DO accept just an array of doubles without the timing information. However in that case the X axis is displayed in samples not time because you will not have given it any timing information.
