application builder
I created an executable to run on PC's without LabVIEW. When I try to run the exe it gives missing dll errors. The program controls a DAQPad 6052E with Traditional daq functions. How do I know which dll's to include in the build?
(3,427 Views)
I fixed the dll problem, but now when I run the exe, I get Labview load error 21. A subroutine required for execution could not be found. This error applies to all of the low level AI and AO functions. Shouldn't all of the AO and AI functions be accessible?
(3,423 Views)
Did you simply include a few DLLs in the build or did you do a full install of NI-DAQ to the other computer? You should do the full install instead of trying to guess which components are required.
(3,420 Views)
I fixed the problem by installing NI-DAQ. Thanks
(3,414 Views)
