at-mio-16x calibration
When calibrating a AT-MIO-16X board with MIO Calibrate.vi, should the EEPROM address be set to 8 (load area) if you want the new coefficients loaded the next time the board is initialized. If the EEPROM address is set to 4, will it be used when the board is initialized. The documentation seems to imply 8 but it is not clear to me if I am interpeting this correctly. I have read the available NI documents on this subject.
(2,571 Views)
Hello jlewis77 -
This is a duplicate post. The answer was posted here.
Becky B.
Becky Linton
Field Engineer
Office: 734-464-2463
Cell: 248-709-2822
Email: becky.linton@ni.com
(2,571 Views)
