attributes into string
I want to read the attributes from the DAQmx and to transform them into a string. How can I manage to do this?
I'm already able to read the channel name that is written in MAX (with get attribute.vi). Unfortunatly this gives me an "attributes" format. I cannot find out how to transfrom this into string. (I want to use the channel name as header in a table)
ThanX for your help
Gilles
(2,912 Views)
it would be great next time, when you have a programmatical question, if you could attach a small example of what you want to do and let us know which versions of LabVIEW and NIDAQmx you use.
Attached you will find a example which reads all existing global channels from MAX and parse them into a string array:
Good Luck with it,
Alex R.
NI Switzerland
(2,882 Views)
