auto increament analog output
hi,
i have usb 6008 device.Does anybody knows how can i create an auto increament voltage at the ao0,that starts at 0v and with a step of 0,5v finishes at 5v?
The attachment below is a vi for current voltage at the ao0.
(3,337 Views)
There are a lot of different ways to do this. You can use the Ramp Pattern to create an array and wire the array though a for loop. You can use a while loop and shift register as shown below.
Message Edited by Dennis Knutson on 11-06-2006 07:00 AM
(3,328 Views)
hi Dennis,
thanks for your reply.It was very useful.I use while loop and shift register as shown at the attachment below,but i have a problem.I see the increase of voltage at slide and after 2-3 seconds i see it at voltmeter.So when slide writes 1v i see at voltmeter 0,5v and when i get at voltmeter 1v slide writes allready 1,5v.How can i solve this problem?Thanks for your help,sorry for my english.
Kostas Stergiou
(3,307 Views)
I can't open your VI as I don't have 8.x. What do you mean by 'slide'? Can you save the VI as 7.1 or post an image of the block diagram?
(3,304 Views)
Slide is the graphical voltmeter at the front panel.I save the vi for 7.1
(3,299 Views)
I think the problem might be the slow update rate of the 6008. Put in a fairly long delay or wait and see if that makes a difference. You could also just set a breakpoint on the DAQmx Write.
(3,295 Views)
