bench mark for 6533
I wanted to know what set was used to arrive at the bench mark for 6533 pattern generation mode 16 bit (1 GB) which tell 1.432 MHz. I wanted to know whether double buffer or single buffer mode was used, PC configuration.
I also wanted to know to what data rate is achievable for transfer data from peripheral to hard disk of the PC.
If you can provide me with the example VC++ used for conducting the bench mark it will be great. My email id is praveenkumar1979@rediffmail.com.
By peripheral data is 16 bit data and clock . I should transfer this data to hard disk.I donot have any other control signal (no handshake). To what data rate can i do this using 6533.
(2,718 Views)
Gool,
Here are some sources of benchmarks for the NI 653x family. It appears that they were performed in LabVIEW.
1. Maximizing the Performance of the NI 6534 Digital I/O Device: http://zone.ni.com/devzone/conceptd.nsf/webmain/E5A26C86E0C32E4886256BE20050E9E3?opendocument
2. Benchmark VIs: http://www.ni.com/devzone/dev_exchange/ex_search.htm
3. User Manual: http://www.ni.com/pdf/manuals/321464c.pdf *Section E
Hope this helps. Have a great day!
(2,718 Views)
