breakout from mutifunction cable to BNC
I have a system using 68 pin multifunction cables, from the (bought-out) analog front-end to the PCIe-6323
The cables are 68-pin on both ends.
I need to be able to take some of the analog signals into an oscilloscope
I took a look at using the SCB-68 breakout box, but I don't think this is what I need - I would prefer not to break any of the connections if at all possible.
Any suggestions?
(1,092 Views)
You can get the BNC accessory as listed on this compatible accessory page
If you need every one of the signals on 6323 on a BNC cable, you are better off outsourcing to a cable assembly vendor to put together your "custom" cable.
Santhosh
Soliton Technologies
(1,060 Views)
