buffer size and timing problems with cDAQ 9188 and Visual Basic
Hi Roberto-
I consulted both the NI-DAQmx Help and the NI-DAQmx C Reference Help documents in order to confirm the information in my posts.  You can find these from your Windows start menu under Start>>Programs>>National Instruments>>NI-DAQ>>Text-Based Code Support.  You can find links to code examples for various text-based programming environments there, as well.
Tom W
Message 11 of 13
(837 Views)
Thank you again Tom, I searched through those files too, but my search wasn't quite good as yours 🙂
Message 12 of 13
(836 Views)
Hey Roberto-
No problem- it definitely takes some experience to build your familiarity with DAQmx.  I would suggest that you peruse the various shipping examples and observe the behavior, then use those documents to tailor it to your specific application.
Good luck. Smiley Happy
Tom W
Message 13 of 13
(833 Views)
