c function references on mxdaq 9
Hi all,
I just installed the mxdaq 9 but... with the default installation there is no c function reference... The mxdaqbase has its one, but its big brother no... Where look for?
(3,182 Views)
Hi Michele,
try to do a custom installation and ensure that "ANSI C Support" (under Application Development Support) is selected.
If you have already installed DAQmx, modify the installation (from Add/Remove Programs) to include the support for C.
Then, you can access help and examples for C languages from Start=> All Programs=> National Instruments=> NI-DAQ=> Text-Based Code Support.
Hope this will help!
Bye!
Licia
(3,155 Views)
