cDAQ 9133 12" MONITOR BLANK
oops! I just saw the post stating there are no current updates for the cDAQ-9133 firmware.
Thanks! so much!
Message 11 of 13
(1,831 Views)
Hi Kyle,
Any update on this? Seeing the same issue occasionally with the cRIO-9030
Cheers,
James
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
Message 12 of 13
(1,199 Views)
Hi James,
This will be a slightly different issue, given that the 9030 is running NI Linux RT, rather than WES7. Are you using the embedded UI or the command line interface?
Message 13 of 13
(1,194 Views)
