cDAQ 9133 Embedded Windows 7 LabVEW BUILD
When building a LabVIEW EXE with LabVIEW Project on a cDAQ embedded windows 7 machine, the LabVIEW Source File Settings Customize VI Properties have no effect. For example, setting the Window run-time position to Maximized does not Maximize the window on execution. Another example is setting the Execution to Run when opened does not have the EXE Run when opened.
The only way to get the Source File settings to work is by building the application on a separate non-embedded Windows 7 machine and then transferring the EXE to the windows 7 embedded machine and running the EXE.
(3,846 Views)
Hello sfroty,
I am not sure if there is a problem with Windows embedded. Have you tried to use property nodes to control de Windows appearance?
This community example shows how to do it with coordinates (https://decibel.ni.com/content/docs/DOC-13727),  but you can use the property node described in this link: http://digital.ni.com/public.nsf/allkb/65C5C5B1D82EAD1486256F350069C973
Randy @Rscd27@
(3,819 Views)
