cDAQ-9172 on MAX 14
After installing LV 2014 on a new machine, I can see my cDAQ in MAX but none of the modules show up under the pull down in MAX.  I've tried installing legacy drivers but they will not replace the new software.
I was wondering how I can select a different driver for my NI DAQ usb.  It says to go to www.ni.com/info and enter 'driverselector' but that throws an error saying there is no such code.
I would appreciate any help.
Message 1 of 10
(6,338 Views)
This website has download links to NI-DAQmx drivers compatible with the cDAQ-9172.
Next, to manually change the driver, go into Device Manager, find your device, right click, and select Update Driver...
From the pop-up you should be able to install the driver from a specific location. Navigate to your driver download and select that.
Brian H. -- Electronics & Measurements Product Marketing Manager
Message 2 of 10
(6,316 Views)
Which version of DAQmx do you have installed?  The 9172 is supported through the most recent release, so there shouldn't be any need for reversion to legacy drivers.  Can you provide a screenshot of your MAX window?
Message 3 of 10
(6,304 Views)
Attached is an image of my max window.
Message 4 of 10
(6,288 Views)
when i plug the cDAQ into my desktop it works just fine and recognizes all of the C modules.
Message 5 of 10
(6,286 Views)
I have DAQmx 14.1 installed.
Message 6 of 10
(6,283 Views)
Are your laptop and desktop running the same version of DAQmx?
Are you connecting the chassis to your laptop through USB? Have you tried another port?
Message 7 of 10
(6,242 Views)
I have NI-DAQmx 14.0 installed on my desktop which is functioning properly with the cDAQ.
Message 8 of 10
(6,236 Views)
I have tried another port on the laptop.
Message 9 of 10
(6,235 Views)
Could you perform a self-test on the device in MAX?
When you go to Device Manager, under Data Acquisition Devices, do you see any of your modules?
Also, could you attach a MAX Technical Report to this post? To get that go to MAX, click File, Create Report, select Technical support report, and attach the .zip file to a post.
Message 10 of 10
(6,223 Views)
