cDAQ 9174
   I use labview 2015 I have cdaq 9174 that I wish to use with some Ni cards. I installed the Nidaq driver 14.5.1.
   My pb is that when I open a New VI in labview, I cant found the assistant DAQ in the block diagram =>Functions ==>Express==> Input?
    When I use Nimax, everything is good.
Thank's
(1,640 Views)
DAQmx 14 is not compatible with LabVIEW 2015.  You will want to use a version of DAQmx between 15.0 and 18.6.
https://www.ni.com/en-us/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.h...
(1,633 Views)
Hi Crossrulz,
  It's works , thank you very much.
 HM
(1,531 Views)
