cDAQ-9178 and Linux support
I am looking for a device driver and C API for Linux which supports the cDAQ-9178 (with 9223 ADC module). Does anybody know if this is available from NI or possible third-party or open source?
Thanks in advance.
Jonas Köhler
(5,659 Views)
For Linux support, please read this page : National Instruments Driver and Software Support for Linux Distributions.
NI-DAQmx Base 15.0 is the most recent driver you can use, but it does not support cDAQ-9178 nor NI-9223. It seems it is not possible to use these harware with Linux.
(5,644 Views)
Hi Mathieu,
Thanks for your reply. This is what I have found myself to. I wasn't really sure so therefore I posted the question here. I also found that there might be support fo usb daq in the future (https://www.ni.com/en/support/documentation/supplemental/18/windows-vs-desktop-linux-daqmx-experienc...
Regards
Jonas Köhler
(5,606 Views)
is it possible to connect cDAQ 91-78  with linux drivers 18.1
(3,956 Views)
Unfortunately, it is not supported.
Kind regards,
Joelle
(3,946 Views)
