cDAQ-9184 AI-AO data delays
Hello, @ Problem was with too small sending buffer to cDAQ. 8k samples and 4 caching buffers works pretty stable. @ I use Python + C-language implementation of NI-DAQmx C, and i have the same problem. How can i change the sending buffer size, using NI-DAQmx C library in C-language?
Message 11 of 12
(612 Views)
Hi Vadeem,
Since this is an old thread, I would create a new one to get eyes on your question.
Here's a link that might help you get started:
How to Avoid Overflow by Changing DAQmx Buffer Allocation in Text-Based Languages
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8nvSAC&l=en-US
Jiwhan S.
Technical Support Engineer
Message 12 of 12
(587 Views)
