cDAQ-9185 Network issues
Hello All, I'm new to the NI world of DAQ and am running into some hardware connectivity issues on a cDAQ-9185 Ethernet chassis.  My issue is BPDU (bridge protocol data unit) guard on my process LAN switch, this 'guard' does not like the 9185 chassis and when it detects the device is disables the port.    I'm working with my local IT and have since disabled the guard on the port to troubleshoot the problem but this workaround may not fit my company's Network policies (TBD).  I think this is related to the chassis TSN feature.
Has anyone experienced this problem?  Is there a way to turn off BPDU or TSN settings?  Perhaps there are other work around?
I appreciate the help in advance.
PC
(4,210 Views)
Accepted by topic author PunchCard
If anyone was wondering........
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NGTSA2
This answers my question.
(4,184 Views)
Hi, PunchCard! XD
It's great to see you found an answer in a National Instruments Knowledge Base.
Please mark your reply as a solution for this forum.
Regards
(4,176 Views)
