cDAQ-9188 SDK
I have this device with model number cDAQ-9188 and I am looking to interface to it so I can save the data to database.  I was wondering if there was a SDK to interface to it via TCP/IP.
Thank you.
(5,640 Views)
The API for programming any module in this chassis is called DAQmx and it can be downloaded at http://www.ni.com/download/ni-daqmx-9.8/4297/en/
What programming language do you intend to use?
(5,618 Views)
Hello Denise,
Thank you for your reply.
I plan to use C# to interface to this device through TCP socket programming.
(5,610 Views)
Please pay attention to what my actual name is and what I said about the driver.
(5,604 Views)
Hello Dennis,
Sorry about getting your name wrong.
Thank you for your help.
I have downloaded Ni-DAQmx Kit and I notice there are a lot of examples there.  I am trying to connect to thermocouples connect to this NI device called NI cDAQ-9188  with serial no 015ED821.
Can you point me to an C# example in that SDK that would be helpful?
Really appreciate the help.
Bhanu
(5,416 Views)
Hi Bhanu0911
There are C examples that are installed with NI-DAQmx if you checked them while you were installing.
Those examples should be in this path: C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C
Please let us know if you are able to find them,
(5,398 Views)
