cDAQ 9219 bridge calibration error
I am trying to measure 4 full-bridge load cells with a 9219 analog input card.
The load cells are 2 mV/V, 350 ohm.
I am using the DAQ assistant.
When I try to calibrate a channel on the card (offset nulling) in the DAQ assistant, I get the following error:
Error -200077
Value: SampQuant.SampPerChan
Requested Vaue: 1
Valid Value begins at: 2
It appears that the calibration dialog is not requesting data properly from this card. Any ideas for solving this?
(3,618 Views)
Hi ahunter10
Seems that the problem that you are specifying a value that is out of the calibration range. This Knowledge Base article shows how to change the calibration range.
Regards
(3,597 Views)
