cDAQ NI-9138 Power Screw Terminal Connector Plug
Terminal Block Highlighted RedTerminal Block Highlighted Red
Hi all,
I am trying to find a replacement Power Terminal Block for my cDAQ NI-9138 controller, like the one highlighted by the red box in the image above. I have found a part number of 782582-01 which is supposed to be the correct power screw terminal kit for my controller, however it is not the same part as in the picture. Does anyone know the correct part number for this terminal block or where I can purchase one from. Thanks in advance.
(1,075 Views)
It's a bummer that NI has put up a 10 position connector for a 4 position plug for 9138 - definitely a website mistake
Anyway, looking at the 9137 connectors and 9138, both look identical, I would think both are the same, may be worth a try to order 783529-01
Santhosh
Soliton Technologies
(1,058 Views)
