cDAQ and NI 9205 NI9203 NI9225 problem with detect modules
We purchased a cDAQ-9188 and NI 9205 modules NI9203 NI9225. My problem is that the MAX does not detects these modules.
The cDAQ should be properly installed and configured as it is in the list of devices. I checked the Device Monitor is running.
Would someone know you help me? Thank you
I have attached a screenshot of NI MAX.
(3,669 Views)
Have you tried resetting the MAX database?
(3,630 Views)
Accepted by topic author Sabpi
The reason of this is that the firewall blocks the ports NI max. Solved by adding exceptions to the firewall
(3,613 Views)
