cDAQ chassis (NI cDAQ9172) detect from windows, don't appear in MAX
i have installed the software NI-DAQmx and everthing was fine but as i run the MAX the modules (NI DAQ 92**) don't appear!!  What should i do??
(3,143 Views)
Which version of NI_DAQmx did you install? Please try with the latest version, and plug the cDAQ chassis in AFTER you installed the latest driver. You can download the latest driver-version here:
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
(3,125 Views)
thanks for the comment, after installed cDAQmx version 8.5 it works!!
THX
(3,115 Views)
