cDAQ
Hello everyone,
I'm planing to built a control and data acquisition system for a Test Stand using NI cDAQ. Due to a high number of inputs and outputs it is necesary to use 2 cDAQ of 8 slots each. My question is, what cDAQ is most recommendable to use in the system USB cDAQ or Ethernet cDAQ?
Thanks in advance,
Alfredo
(4,429 Views)
I think that both options are valid. Ethernet is ideal for taking measurements at distances beyond the 5 m limit of a USB cable. If the distance is not a problem, then you might to consider the bandwidth for both buses. Depending of your network configuration USB connections could allow you to transfer more information. Take a look to the next link to see the differences for the USB and Ethernet buses.
https://www.ni.com/en/support/downloads/instrument-drivers/how-to-choose-the-right-hardware-bus-for-...
(4,403 Views)
Accepted by topic author Busu
Hi MCOTO,
I found enough information (in the article you sent me) to choose the best bus for my application
Thank you very much
Busu
(4,390 Views)
Hi, I have a cDAQ 9174. I'm trying to measure vibration signal. But, I connected the USB and power cables and my computer doesn't read nothing. The LED's: power and active always are on and the ready LED is off. Somebody know what problem is happening with my cDAQ?
(4,237 Views)
Hi pcbmeng,
To better support you, please create a new forum post for this issue.  Since this issue is not related to the original forum post, which already has a solution, your question might not be seen by people monitoring the forums.  This also helps create problems and solutions organized for future use.
Nick
(4,221 Views)
