cDAQ9188 in C
Hello all
I am trying to run cDAQ9188 with 03 NI 9205 modules installed on it in single task (for auto synchronization) using C APIs given by NI. For single NI 9205 module installed on cDAQ9188, following works fine:
DAQmxErrChk (DAQmxCreateTask("",&masterTaskHandle));
DAQmxErrChk (DAQmxCreateAIVoltageChan (masterTaskHandle,"cDAQMod1/ai0:31","",DAQmx_Val_Cfg_Default,-1.25,1.25,DAQmx_Val_Volts,NULL));
When i install all 03 modules, i get cDAQMod1,cDAQMod2,cDAQMod3 device names. How should i define all three devices in "DAQmxCreateAIVoltageChan" API so that i can acquire all 96 channels in single task (with auto synchronization of three modules)?
Best Regards
asim
(3,299 Views)
Accepted by topic author ASIM_BHATTI
Hi Asim,
I'm not certain, but I beleive it may be similar to:
DAQmxErrChk (DAQmxCreateAIVoltageChan (masterTaskHandle,"cDAQMod1/ai0:31,cDAQMod2/ai0:31,cDAQMod3/ai0:31","",DAQmx_Val_Cfg_Default,-1.25,1.25,DAQmx_Val_Volts,NULL));
Let me know how this works.
Kaitlin N.
(3,262 Views)
Dear Kaitlin N.
Thanks, It works fine
(3,243 Views)
Great! Thanks for letting me know!
Kaitlin N.
(3,235 Views)
