cDAQ9188 on one network card disconnects with activation of VPN on another network card
Hi!
I have a cDAQ9188 Ethernet chassis connected to the network card at my PC (Win XP). Another network card makes a wireless connection to Internet. However, I have to make a VPN connection additionally each time I want to access Internet.
Until I don't start a VPN cDAQ9188 is discovered by MAX and working (wireless connection on the second adapter may be activated at this moment), but if I want to access Internet, after I sart VPN the device is not active anymore (status is "Disconnected").
Would anybody be so kind to advice me, how to overcome this problem? If I stop VPN and self-test chassis the latter is working again, but I can't access Internet and use chassis at the same moment.
(4,029 Views)
Hi _Basil_,
I think you should be able to work around this behaviour if you use split tunneling.
Split tunneling - Wikipedia, the free encyclopedia
http://en.wikipedia.org/wiki/Split_tunneling
There are several tutorials out there - you should be able to find them with this keyword.
Best Regards,
Peter
(3,961 Views)
