cDaq and 9219 change measurement mode in LabView
Hi!
I am using a NI cDAQ-9178 and NI-9219 I need to be able to measure 0-25 mA on all channels but I also want to be able to measure resistance in the system.
Can I use the same channels to measure resistance and then switch to current measurement in the same LabView program using DAQmx?
(3,777 Views)
If you want to switch to an other measurement you basicly switch the configuration to antother one.
So yes it should be possible.
(3,696 Views)
