cFP-1808 + AO200 value latching anytime and not refreshing
We are facing a problem which become very serious as we are using this hardware (CFP-1808) at very critical process control.  Setup DetailI/O Rack - cFP 1808AO Module – AO-200Development Software – Lookout V 5.1Driver Object in Lookout – Field PointCommunication Mode – Ethernet ProblemWe have installed all AO-200 module on this rack. There is a problem of latching of any (random or last) values at its all or any channel and it is not changing even there is further change by software. The problem is not arriving all time but happens any time. Problem ExampleIf the last written value at a particular channel by software is 80, it does not change even by changing any new value. Again repeating, the phenomenon is not happening all the times but it can happen any time. So, we request to all to search out the solution of this problem at earliest considering the danger of said failure at critical process.
(2,950 Views)
Anybody need more clarification about the problem so that he/she can resolve the issue.
Sangeet Kohli
(2,930 Views)
