cRIO-9081 Module ID
I am using an FPGA I/O Property node to get the Serial Number and Module ID for each module in my cRIO-9081.  The serial numbers match exactly what I thought was in my cRIO .  However the Module ID did not make any sense.  I thought the Module ID would have been 9201 for a NI-9201 module.  I got a number: 21754370963.
What should the Module ID be?
(4,880 Views)
Accepted by topic author Paul_Knight_Lockheed_Mart
Hello Paul,
The module ID returned by the Module ID property is not the actual module name (ex. 9201). Instead, it returns an ID which you can then match to a specific module as described in the link below.
C Series Module IDs:
http://zone.ni.com/reference/en-XX/help/370984R-01/criodevicehelp/module_ids/
j_bou
(4,862 Views)
(4,854 Views)
