Multifunction DAQ
cRIO Witch pins are used by NI 9944 9237
I use a cRIO with an NI 9237 module for the measurement of strain with strain gauges. Here I use the the NI 9944 adapter to connect to strain gauges. I have a large number of SG and spread over a large area, so I have thought about to build  little boxes in which four adapters are installed. Now I will not always use 4 RJ50 cable to connect the boxes, just one. This cable should not consist of 40 cores (1x RJ50 = 10 cores), but use only the cables are also needed.
Now my question is what pins of the NI 9944 are even used a to connect a quarter bridge?
I hope someone can help me
Matthias
(3,424 Views)
Accepted by topic author MaJahn
Hi Matthias,
here I have a document which should help you:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OptSAE&l=en-US
:D,
RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(3,400 Views)
Thanks Matthias  Smiley Very Happy
(3,398 Views)
