calculation for resolution
Hi, I'm a mechanical engineer and amateur in the electronic world. I would like to know what calculation is required to find the resolution using a 6009 DAQ?
thank you!
(2,991 Views)
I need to know which amplifier I should use, please help me!
(2,946 Views)
Hi fabiogiga.
You can use the following formula in order to calculate the resolution:
Absolute Accuracy = ±((Input Voltage * % of reading) + Offset + System Noise + Temperature Drift
You can find more on that here: Differences Between Accuracy, Code Width, and Bits of Resolution
Best Regards,
Lígia T. Ferreira
Technical Support Engineer
National Instruments Brazil
(2,920 Views)
