call AI single scan.VI by 3 separate labview programs
I have three different Labview programs trying to access one SCXI chassis.
I look at the example semaphore with 3 subvi in parallel.
1. Create semaphore
2. passing semaphore reference to 3 subvis
3. destroy semaphore.
this example does not work for me.
I have three different subvis, they are not running at the same time or terminating at the same time.
My scenario:
at 7AM operator 1 launches VI1
at 8AM operator2 launches VI2 a different program
at 9AM operator3 lauches VI3 another different program.
they all access SCXI chassis, different channels.
attached are the VIs, semaphorecall.vi; semaphorecall1.vi; semaphorecall2.vi these 3 VIs will call semaphore with subVI100.vi at different ti
me.
What should be the right place to call destroy semaphore.vI
(2,608 Views)
There is an excellent tutorial on semaphores on our website, and the tutorial includes an example program of using semaphores within 3 parallel subVIs. I have included a link to the tutorial below. This should be a good reference for you. I hope this helps.
Using Semaphores
http://zone.ni.com/devzone/taskdoc.nsf/2d17d611efb58b22862567a9006ffe76/71b61d18f12980c586256802007b9155?OpenDocument
Todd D.
(2,608 Views)
