can 6008 oem daq card can short circuit after 10 hrs of continous work?
i was workin with 6008 daq and it was switch on for almost 10 hrs ...can it stoped workin because of this reason ?
Regards
(3,066 Views)
Hello nolsqn,
Generally, these devices are designed to operate for much longer than just 10 hours.  This might be a case of an external signal that shocked it, but it's most likely not from just running it.  Anything else you can offer so that people can give suggestions on what to avoid in the future?
ColeR
Field Engineer
(3,046 Views)
thnx ... i found the problem ....i was caused by a short circuit ......entirely my fault 🙂
thnx
Regards
(3,017 Views)
