can i assign different sampling rate to different channel in 1 DAQ device (PICE 6321) using matlab?
Can i assign different sampling rate to different channel in 1 DAQ device (PICE 6321) using matlab?
(1,311 Views)
Accepted by topic author LeeGwanWoo
 Assuming you're talking about two or more analog channels, then no.  This is a limitation of the way the DAQ device is designed, and it will apply whether you're using Matlab, C#, Python, or LabVIEW.
A typical workaround is to acquire at the higher rate then use decimation / interpolation to reduce the apparent sample rate of the slower channel(s).
-Kevin P
(1,278 Views)
See Sample Channels at Different Rates with Multifunction DAQ Device
https://tmesystems.net/
(1,271 Views)
Thank you!!
(1,267 Views)
