05-25-2008 06:59 PM
05-27-2008
12:49 PM
- last edited on
10-05-2025
02:29 PM
by
Content Cleaner
Hi Loay,
The 6009, along with the rest of our DAQ devices, can be used in LabVIEW with the DAQmx driver. There are many shipping examples (Help » Find Example...) with LabVIEW that can assist you in achieving your results. Also, look at the following links for great tutorials about how to use DAQmx in LabVIEW. Please note that the 6009 is a software timed device and therefore deterministic applications are to be avoided. Also, if you are using a DAQmx Base driver(Macintosh and Linux), you will need to make sure you have the current version and also run lsdaq and the firmware updater to ensure proper functionality.
Getting Started with NI-DAQmx
https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
Getting Started with NI-DAQmx: Getting Started with NI-DAQmx Programming in LabVIEW
http://zone.ni.com/devzone/cda/tut/p/id/5468
Getting Started with NI-DAQmx: Using the DAQ Assistant
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1AFCAY&l=en-US
05-27-2008 04:22 PM
05-28-2008
11:57 AM
- last edited on
10-05-2025
02:29 PM
by
Content Cleaner
