cannot see property of my NIDAQ
Can anyone help me figure out why I cannot see property of my NIDAQ: USB6008. See the pic, it is gray... Is it normal? Thank you~
Kangmin
(3,290 Views)
Hi Kangmin,
I think it is greyed out because you are currently in the properties page. To the right you see the serial # of the device, which is a property. You can verify this by looking at the bottom of the page and look for a tab name.
Chris Co.
(3,267 Views)
Hi Kangmin,
The reason that properties is greyed out on the USB 6008 is because none of the properties this menu allows you to set are available on the 6008.  For example, the properties page is typically used to set the accessory you are using, change power up states, and set RTSI cable settings.  Since none of these features are available with the 6008, the properties page isn't accessible.
I hope this helps,
Paul C.
(3,236 Views)
Oh, I see. Thank you for all your replies~
(3,232 Views)
