capture a low frequency sinusoid with PXI-4132
I would like to drive a 275Hz 2V amplitude 2V offset above ground sinusoid into the sense hi lo pins of the  PXI-4132 & try to capture it to do an FFT & look at the quality of the waveform.
I have tried to drive those pins directly without luck, &then tried to drive the hi lo pins as well, with the compliance set low enough to overdrive the inputs.
I  would  also  like the PXI-4132 to generate this sinusoid for driving a DUT.
This card sits in a PXIe-1073 chassis connected to an windows xp PC runnig labview 2011 SP1.
Any help would be appreciated.
(4,018 Views)
I Never work with this Devise, just Looping alt the online help, my starting Point World be to Set the device into current Mode, maybe 1mA , add a 10k resistor Tod the Output, and configure the Sense Inputs for for Voltaire Reading.
I hate the autocorrection of my wifes iPad... (Using a German KB)
However Voltaire instead of voltage made my day 😄
Greetings from Germany
Henrik
LV since v3.1
(3,996 Views)
