capturing images in machine vision
HI,
I want to capture the pendulum movement using machine vision and want to calculate the damping time period and frequency of oscillation.
How can I do that and can go about that.
(2,908 Views)
Hey tmdar,
There is another Discussion Forum post that talks about how to do this using the NI Vision software. Check it out at the following link Period of a Pendulum Using Vision. Let me know if this is not what you are looking for or if it doesn't answer your question. Thanks, and good luck on your application.
DJ L.
(2,862 Views)
