caracterization of solar cell in real time with labview
Hello everyone,
I am contacting you because in the context of a school project, I need to create a simulation of photovoltaic performance. I am a beginner in labview and meet a lot of difficulties!
So I want to buy a voltage and a current from the PV cell, via a DAQ Card USB6221. The idea is then to exploit these data: Get different curves of voltage and current (over time) to generate a graph I = f (V), thereby obtaining the characteristic of the PV cell, and finally to from this graph, get the key values of the cell (max delivered ...).
So I started by using the DAQ Assistant (acquisition of a voltage + current), converted the dynamic data in 2D array, then tried to use this table but I can not do it!
Firstly, I feel that the picture is not incremented, suddenly no data is usable!
I then very difficult to identify this "he goes" DAQ assistant! The same applies to the conversion of dynamic data.
I do not know if I was clear, but I need your expertise on Labview in order to advance my project.
Thanking you in advance.
(3,003 Views)
I'm not sure exactly what you application is, but you should check our examples on taking voltage data.  Go to help, find examples->hardware input and output->DAQmx-> analog input, and there should be a reading that matches the type you want. That is probably a great starting place. From what I understood you probably want continuous voltage.
TimC
(2,976 Views)
