card 6713,if I can internaly measure output current
I use 6713 card with Visual Basic. I am using digital and analog output siganals to control external TTL devices. Can I internaly via software measure digital and analog outputs load current.
(2,547 Views)
Greetings,
The NI 6713 can not internally measure the digital and/or analog output currents. Check out the link below for which NI products can be used to take current measurements.
Can I do Current Measurements with NI Products? Which Ones? How?
http://digital.ni.com/public.nsf/websearch/29534F94B158054486256B490059E3AD?OpenDocument
Todd D.
NI Applications Engineer
(2,547 Views)
I received a discussion forum activty email in
response to your comment on the original post.
Either someone is using my login and password or
a glitch occurred. I am not currently using the
NI 6173 and never posted a question about it.
Would someone at NI please investigate this?
(2,547 Views)
